Handrest
martan
Handrest
Post by martan »
Handrest for a Swedish fighter jet:
Quite easy job. As usual 2x DMK 23UX236 with Computar 12mm and Optoma 750e.
RMS of 0,11 and 0,08. Calibration panels HP at 120mm. DIY Rotary table.
Mostly stereo mode except for the cavity (extended mode).
Re: Handrest
martan wrote: 16 May 2019, 19:21 Handrest for a Swedish fighter jet:
Great work.
Thanks for sharing.
Re: Handrest
Wow!
A very nice work Martan!
Still I can't realise why my 120mm panels performs so differently.
Are rms independent from the projector?
martan
Re: Handrest
Post by martan »
@mading,
I can check my settings again and send to you.
A faint memory about "panel angle compensation setting" affecting the RMS error quite heavily.
Re: Handrest
Thanks martan. You are very kind.
I'll take a picture of the panel and share it in another post. I thinks it's poorly printed.
martan
Re: Handrest
Post by martan »
v 5.2
Don't think I changed anything else.
Settings
Settings
illbefucd2
Re: Handrest
Post by illbefucd2 »
Great job.
Thanks for sharing :)
martan
Re: Handrest
Post by martan »
The "joystick top" that sits in front of the handrest. Mesh and solid.
solid
solid
mesh
mesh
erapip
Re: Handrest
Post by erapip »
Hello martan,
Very good scan? Have you 3D Print the first Handrest? If you van share the STL i would like to 3D print it and see the top details how it will look.
Nice job!
Regards
