Vanishing Scanning Spray
Re: Vanishing Scanning Spray
martan wrote: 08 Nov 2019, 11:48 ... for 300 Euros / 12pcs ...
It’s a pity that this is only slightly less than my monthly salary ... :(
Mr_Lafuente
Post by Mr_Lafuente »
I use PlastiDip. Its easy to peal off and its not expensive:
https://youtu.be/sIUbG4f2tMw?t=86
Mr_Lafuente wrote: 15 Jan 2020, 22:04 I use PlastiDip. Its easy to peal off and its not expensive:
The problem with plastidip is that it's thick and distorts the dimensions and sharp feature of the part you are trying to scan. Ideally with scanning spray you want a very light dusting.
Micr0 wrote: 16 Jan 2020, 01:00 The problem with plastidip is that it's thick and distorts the dimensions and sharp feature of the part you are trying to scan. Ideally with scanning spray you want a very light dusting.
I completely agree - the other day I had to scan a large semi-precious stone for the ring (it has a not quite standard shape, and it was very difficult to measure everything exactly), and due to the absence of any spray, I smeared it with a white “corrector for correction text on paper "- at least the form turned out (which I needed), and the edges are poorly visible.
Mr_Lafuente
I just found this thread on Reddit:
https://www.reddit.com/r/3DScanning/com ... d/d1fl4lp/
kodex1717 seem to have tried some diferent ones and said about this Spotcheck SKD-S2 Developer by Magnaflux, wich surprisely is very cheap in my country. I paid 15 USD for a can. Will try it next week.
Mr_Lafuente wrote: 24 Apr 2020, 16:21 I just found this thread on Reddit:
That"s the stuff I use. Works well. don't spray it on too heavy. it's easy to think you haven't sprayed enough, spray more and realize when it dries that you oversprayed. It can be then a bit difficult to get it completely off. It tends to like to stay in the nooks and cracks.
ibhurln
Post by ibhurln »
ive tried anti-fungal/athlete's foot spray that works really well for smaller scans and is cheap.
For larger scans, i use an automotive style HVLP paint gun with a mixture of baby powder and rubbing alcohol.
The alcohol evaporates immediately leaving the fine white powder behind. It only takes a light dusting to get great scans.
The only downside is washing or blowing the powder off when you are done.
Post by bigbomber »
Does anyone know if PT Developer spray is harmful for human or not?
what kind of material is it made?
bigbomber wrote: 24 Jul 2020, 17:47 Does anyone know if PT Developer spray is harmful for human or not?
Hey Bomber.
Where have you been?
If you go to mcmastercarr.com, search for developer. They have a link to the MSDS.
Post by bigbomber »
Micr0 wrote: 24 Jul 2020, 19:47
Hey Bomber.
Hi dear Friend. I'm So busy these days.
Thank you for your info.
Actually I use developer spray for vanishing. but I'm afraid about this white powder.
