Some of my scans
Re: Some of my scans
RangeVision
Hello, we offer software as Do-It-Yourself solution only for individuals, private and non-commercial use
good
good
Gennaro
hi I'm interested in your software how can I buy I'm in Italy
thank you
RangeVision
Gennaro
certainly for personal use only
RangeVision
Do you have suitable cameras?
Gennaro
the cost including calibration tables
2 Daheng MER-630-60U3M
RangeVision
Gennaro
Yes, for 3 zones, and license USB dongle
Gennaro
cost ??
RangeVision
~350 EUR + shipment, depends on currency rate
Gennaro
ok how to order it?
RangeVision
I'll share your contact with my colleague, he will contact you on payment and shipment details
Gennaro
I also forgot the small rotary table
RangeVision
The cost is about ~250EUR
Gennaro
ok
I await your colleague for instructions
thank you
thank you
RangeVision
Gennaro
RangeVision
Gennaro
RangeVision
Gennaro
Gennaro
cost ??
RangeVision
Gennaro
ok how to order it?
RangeVision
Gennaro
RangeVision
Gennaro
ok
thank you
Great.
everything with telegram?
WHY DID YOU CHOOSE THIS
AND NOT THE SECOND?
1 MER-630-60U3M-L
Synchronization software trigger
2 MER-630-60U3M
Synchronization Hardware trigger, software trigger
AND NOT THE SECOND?
1 MER-630-60U3M-L
2 MER-630-60U3M
Only because I have nothing to use an external trigger with, and none of the programs I use support it (and the camera version without it costs a little cheaper)dental_art wrote: ↑05 Oct 2020, 10:13 WHY DID YOU CHOOSE THIS
AND NOT THE SECOND?
1 MER-630-60U3M-L
2 MER-630-60U3M
I live in the USA, and I received my Rangevision about a week ago.
I asked for a quote on the website. I did not know about the turntable and will see about that soon.
I installed it and the software has not been able to see my cameras, although I can see them with the SDK software of the Dehang Cameras.. Win7 and Win 10.
I have been very busy, and have not had much time to use it yet and troubleshoot.
It was sent by Russian Postal Service and arrived by US Postal Service. Took about a week.
I hope to get a little time this week.
One of the last scans made on a homemade 4th zone (not included in the delivery set). An old HD projector was also used, because it can focus at a much shorter distance (and thanks to the higher projection ratio from 150mm, it provides almost better pixel density than the new FullHD projector from a distance of just over 300mm) Download the model(55mb stl) can hereOBNRacerMan wrote: ↑05 Oct 2020, 12:00Only because I have nothing to use an external trigger with, and none of the programs I use support it (and the camera version without it costs a little cheaper)dental_art wrote: ↑05 Oct 2020, 10:13 WHY DID YOU CHOOSE THIS
AND NOT THE SECOND?
1 MER-630-60U3M-L
2 MER-630-60U3M
Synchronization Hardware trigger, software trigger![]()
Important! For work in the 3rd zone, a lens with a focal length of 16mm is optimal, for the 4th zone the program asks for a 25mm lens - but, with some tweaks, you can use the same 16mm. But on the 1st (~ 300mm) and 2nd (~ 150mm) zones, I have not tried to scan anything yet (for them, 12.5mm (12mm) lenses are recommended).
Have you only installed drivers on cameras?
I, in addition, put Galaxy DirectX SDK
After installing it, I ran GxDirectShowRegister from this folder, and in that field indicated to register TWO DirectShow devices
Excuse me for the question.
Are these cameras daheng MER-630-60U3M OK for HP3D also?
https://www.get-cameras.com/USB-Camera- ... -630-60U3M
thanks
thanks
