Hello, does somebody of you have experiences in scanning a large object by partwise scanning?
I recently build a large calibration panel (which sems to be working)! at a scale of 666 mm / Din A0.
Of Course, accuracy is reduced and the surface is very rough. So mybe not the best idea? - Can i stay smaller and more accurate by using more patches?
David states that people should choose the calibration corner size according to the object size.
Do i need at least a calibration scale of 400mm to scan 400mm, or how far it is possible to stay smaller in calibration and merge single scans?
Any experiences?
regards, spark
partwise scanning
Re: partwise scanning
I have a 160mm calib panel and scan object larger than 1m. The goal is to have a very good calibrated setup and scan object partially and aligned scans together.
amazing, do you use the whole scan, or do you clip the scan result on its borders to get rid of inaccuracies?
How can i identify a very good calibration?
single or dual camera? regards, spark
you must use all whole scans with big portion of overlaps.
I use dual setup. and for good calibration: you can check accuracy of calibration when you are aligning scans. with a good calibration all scans must align completely with minimum deviation.
