MindVision SUA630M (USB3.0 IMX178)
hoffybeefe
Re: MindVision SUA630M (USB3.0 IMX178)
Post by hoffybeefe » 12 Feb 2020, 00:34
Hi OBNRacerMan,
Thanks for the info. I will consider the pro's and con's just a little longer and then just take a dive. :) I will report back with a new post depending one which way i go so i can add to the information should it be a different camera.
Post by OBNRacerMan » 13 May 2020, 11:36
Just yesterday, I took my second "cool" camera from the post office (due to the "wrecking" actions of our customs, the saga with its purchase lasted for several months).
The second camera is also based on the very advanced SONY IMX178 matrix (I bought a monochrome version specifically for use in the scanner)
I already managed to try it - and found out that both of these cameras (despite the specific features of David / HP's interaction with DirectShow) work in HP3Dscan - for this you need to change the camera name through the driver (if the names are the same, only one camera will be seen).
Both cameras are up and running
P.S. At the same time, cameras with UVC support that work without special drivers can have the same name and not have problems with this.
Further development involves the transition to a more advanced (and, most importantly, actively developing) ScanCenter software from RangeVision. I already bought a kit from the program (license key), calibration panels of three different sizes, and, in addition, an automatic turntable controlled by the program (it has not yet been delivered to me).
Set of calibration panels and license key.
However, there are problems with the support of my cameras program (I really hope that the manufacturer will be able to introduce support for such cameras).
hoffybeefe
Post by hoffybeefe » 14 May 2020, 07:18
Good Evening,
Thanks for the info! I've managed to jump in with Basler so i've ordered that camera and have been waiting about 2 months and by the looks of it i'll be waiting another month at best (thanks virus). I shall repot my success or fail eventually.. hopefully. :)
Thanks for the other scan software name.. i shall investigate it for its viability as a future option. If its as good or better then HP3DScan (RIP DAVID) then i'll be excited (assuming its cost is not prohibitive like FlexScan3D).
Post by mading » 14 May 2020, 07:30
In EU rangevision is not selling the software.
At least it's what they told me.
We are waiting for your updates!
HP 3D scan, Acer K132, LG PF50, 2x DMK23UX236, 2xComputar M1214, David Calibration panels, Melamine panels, DIY rotary table
Post by OBNRacerMan » 14 May 2020, 08:45
mading wrote:
14 May 2020, 07:30
Yes, the program is available only to a limited number of Russian fans who have created their 3D scanners and are actively involved in the development of the community.
At the moment, owning this program is "nominal" for me - my cameras do not yet have support in it (officially there is only support for IDS cameras and some ToupCam). But I communicate with representatives ... according to them, if the introduction of support for cameras like mine does not require big changes, then they will implement it (in the beta version support for Daheng cameras appeared)
Post by Micr0 » 15 May 2020, 13:07
OBNRacerMan wrote:
14 May 2020, 08:45
mading wrote:
14 May 2020, 07:30
Fascinating. Thanks for sharing this.
Looking forward to seeing the results of your new cameras.
Post by OBNRacerMan » 15 May 2020, 16:58
15 May 2020, 13:07
I posted the scan results here
hoffybeefe
Post by hoffybeefe » 18 Jun 2020, 09:00
Well, today i finally got the Machine Vision camera delivered. The Basler acA3088-57um. I connected it up to the computer after installing the latest version of the pylon software from Basler, fired up the software and had a quick play to see if it was functioning and all in working order. Luckily, it was fine and everything seems to be in order!
Once i did that i found my HP 3DScan hardware key and plugged it in and fired it up. So far... no joy. It doesn't seem to show up in the camera list at all. So i'm stuffed! So it appears my gamble did not pay off at all and i'm stuck now with the perfect bit of camera kit for SLS scanning and no way to be able to use it. :(
Perhaps i should have went with the FLIR.
Post by OBNRacerMan » 18 Jun 2020, 09:22
It is very strange that David / HP3DScan could not see your camera (I tried a sufficiently large number of cameras with it, and the only thing that it could not see is the RGB camera built into Kinect (well, there is a very specific design and drivers) ... And even the RGB camera from Intel Realsense D415 he saw perfectly.
hoffybeefe
Post by hoffybeefe » 18 Jun 2020, 10:19
OK i think i've just figured it out. I naively assumed that installing the pylon software would install all required drivers etc but it seems it doesn't. So i found the additional drivers (like SDK etc etc) pack and installed it as a last ditch hope. Rebooted and voila. It how shows 4 entries and i tried the first one and there it is.
Now my disappointment has eased to jubilation and i'm off to do some quick and nasty setup and testing and to design and print a mount so i can hold it on my tripod for said testing. :)
