David3 support 1 Firewire camera.
David5 2 does not support Firewire camera. (Basler A622f)
1 is detected, but not in use.
Does anyone have a problem? There is a solution?
David5 - dual FireWire camera
Re: David5 - dual FireWire camera
To be honest, I have no idea. Have you tried to contact the David/HP support directly? No idea if there is a point in this now after the merge, but I would at least try it.
Sorry to be of so little help
Windows10 64bit - half the battle.
2 Firewire connected cameras.
David5 not support the same two Firewire cameras. (Basler A622f)
Use one Firewire next to one USB3 camera.
It works with two different cameras.
I have the Marlin FireWire cammera but HP 3D scan is not showing it. How did you succeed do connect it?
Do i have to use any “generic 1394 desktop camera driver”
Thanks!
Thanks!
Please how to connect the Firewire Cammera? David 5 can not see the cammera. Should i use something like sparkocam, or modify the driver name?
PS: Marlin firewire cammera
Thanks for the help!
